Thanks for the invitation Shadey, but I've already ordered an ELM cable, so now I'll have both
Cheers for all the help,
Andy
Andy
I have this cable(actually I have a lot of cables), works very well, you'll have no problems connecting to the Airbags. No adapters needed as it has a micro switch fitted.
http://www.ebay.co.uk/itm/FIAT-ALFA-VAG-USB-ODB2-DIAGNOSTIC-LEAD-FiatECUScan-/150677750230
Have you tried looking at the airbags with this?
Yes, but I have to admit I was scared to do anything once I'd connected to it. I had a quick look around and logged out.
However, I've had other forum members ask for help and I've let them use my laptop and cables to clear their Airbag faults with no issues.
Why scared
Did you adjust the latency timer / buffer limits on the port? When im looking at the airbag screens its seems to want to timeout. Just easier to ask what settings youve adjusted it to than go potching .
Yes I did. This will show you how if your not sure.
http://www.fiatecuscan.net/HowToUse.aspx
Off topic:
Whats "potching" mean?
Thanks shall 'potch' about with the options o.
Not a term I would usually use, in this case i meant playing about with the settings to get it to work.
Yes you can, but only with the registered and paid for version.
thankyou! do you know which leads i will need for this i have just ordered a vagcom one off ebay.
thanks again
