Hi to all. Hope here I'll find a little information about the front suspension. A cople of times i had problem with the bolts(marked with red circle). Now i start to think that the main problem is also with that rubber element.
Can someone with more experience in fixing and repair to advice me is it normal that situation (on picture).This wear of the rubber
I'm curious because in that situation like on the picture above(lifted car without tire) if i push a little with hand touched on place where is stay the weel from right to left i see how the back side of the metal arm moves about 6-10mm around that rubber ring I'm still thinking that this is not normal..
- 1st question - if i untwist te bolts keeping the arm to the body front and back but not the balljoint can i replace that rubber circle?
- 2th question - is it something special when i put the new one - except fact that this rubber with the strongest side need to be on front-end line?
