I have a big graphic display in between my rev counter and speedo which is quite happy to flash and beep when a sensor is on blink but nothing for this CITy buton! im not really that fussed if its working or not all I'm worried about is if its perminently on and wearing components out!? I will just do a few test and see how its feels to park.
In that case, you have an Abarth (I'm guessing).
The 'CITY' comes up on the odometer display, at the base of the speedo - look for it again
I don't believe in this 'wearing components out' business (as I posted back in March
) - the only high-wear time for the steering is when the wheels are being swivelled when the car is not moving. If you avoid this (as you should), then there shouldn't be a problem.
I've now bought a Mk2 Punto and the 'City'/Normal difference is much more noticeable than it was in the Stilo.
<RANT>
To be honest, the steering feel of neither car is all that great, and that comes down to geometry, tyre choice, anti-roll-bar stiffness, ride quality compromise etc. The weight of the steering is not that big a difference in my opinion - it's more about how stable it feels rather than the effort you put in. For instance, my unassisted Uno Turbo steering is all over the place (and extremely light) at high speeds. By "all over the place" I mean that it kicks back, follows lines in the road, has no self-centering, etc. If the geometry were different to make the steering heavier (e.g. more caster, negative scrub radius), that may help things. But if it had electric assistance, turning down the assistance would not change the geometry - see where I'm going with this?
Some old cars with narrow tyres and slimmed-down suspension parts (low unsprung weight) have great steering - precise but also unaffected by bumps, camber change of the road etc. Maybe try driving a FIAT X1/9
The steering's very light but also very smooth - excellent feel. And there's no power assistance at all. This is mainly because the weight of the engine is not over the front wheels.
Cars like the Stilo have fairly high unsprung weight (the moving parts of the suspension)compared with the older cars (one 17" wheel and tyre weighs 18kg compared with 10kg for the old 13" alloy), larger brakes, hub carrier, strut base, anti-roll bar, control arms that have to be sturdy enough for urban conditions etc) and this is all deflected when you hit a bump, creating work for the dampers which have to be compromised for ride quality. The amount of steering assistance doesn't change any of this.
Cars like my Alfa 164 have the same unsprung weight but more sprung weight (body and engine etc.) so the ride quality improves. The weight and the wider track seems to help the steering. It's quite light but more to the point, smoother than the Punto and the Stilo. Over the years I've decided that I like large front-wheel drive cars, expensively-designed, and with fairly soft suspension
To sum up, the CITY function works well and I don't think there's anything to be gained by turning it off, because there are several other factors that affect the steering to a greater extent than adjusting the assistance is able to.
As for traction control, I found that worked well on wet roads when driving out of T-junctions etc. I did some tests at a racetrack (in the dry) and I can assure you that there is no difference in acceleration times between ASR on or off. With the latter you get more wheelspin, but that doesn't make it faster. Many earlier cars with traction control reduce the engine power (FIAT calls this MSR - Motor Schleppmoment Regulung, which is German of course for Engine Torque Control). The Stilo does this only when both wheels spin - if either wheel spins, it is supposed to brake the spinning wheel so that the differential gives an LSD effect (according to the handbook). My tests suggest that this works, but nothing better or worse than feathering the throttle does if you have ASR off.
ESP (Stability Control) is another contentious matter. People say that you go faster on a track with it off. Again, I tried this, it's not true. By the time the ESP intervenes, you are already wiping off speed sliding (the understeer has to be really, really bad before the ESP intervenes) and you have to be very deliberate trying to get the back to step out before you feel the ESP intervene. It is seemingly impossible to spin the Stilo Abarth - you simply shudder to a halt. This is surely a good thing... If you are deliberately trying to drive sideways, the ESP WILL prevent you doing this, so if you are doing a gravel rally, you probably ARE better off without ESP. However there are other problems before this happy sideways-state is reached (roll damping, that understeer, etc.) so again I feel that the ESP is way above the point at which you lose 'best handling'. The ESP is a safety net only, and neither hinders nor helps handling performance.
Much the same goes for ABS - all good race drivers with 'normal' brakes can out-brake cars equipped with ABS and there are myriad reports of ABS not working properly on snow etc. because it does not allow a 'wedge' of snow to form in front of the wheel.
But on a wet night, with a fatigued driver having a slow reaction time, the ABS prevents the wheels locking, the electrically-assisted steering helps the driver to swerve quickly, and the ESP prevents the back end from coming around. It all works together and it does serve a purpose - it could save someone's life.
</RANT>
Cheers!
-Alex
