larzmaster
As some of you probably know, I replaced my original 1.2 dash with an Abarth dash.
The Abarth dash has connections for an oil pressure and oil temperature sensor - as they are not connected this generates a "loose connection" warning because the dash expects a certain resistance value on pin 1 and 2 of connector C on the back of the dash.
Does anyone know the necessary resistance values from the Stilo maintenance CD? I would like to try and connect a dummy resistor between these pins and ground to simulate a certain value for oil temp. and pressure.
I hope this will make the error message disappear.
Thank you very much for your help!
Best,
Lars.
Best,
Lars.
