numero-uno
Just had my fiat standard springs replaced for Eibach pro kit (-30mm). Now I can drive my car with peace of mind, knowing that the other spring isn't going to snap as well.
It took the mechanic about 2 hrs to fit all 4 springs and adjust the tracking.
The job looked so simple with the right tools. The front springs are obviously hardest to replace, as this requires the suspension arm to be removed from the car, then a spring compressor is used to remove the spring. It took just 35 mins to replace the rear.
The tracking was apparently by 6 degrees. I was advised this was due to the new springs and previous misalignment, shown by slight inner tyre wear.
before lowering
after lowering
I car seems to be slightly lower than before, as seen in pics. I'll keep you posted about the handling, going over bumps etc.
before lowering
after lowering
