FIAT Auto Specialist Team
Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Steering column switch repair<!-- google_ad_section_end -->
Weak turning signal lever
Published by roll
2 Weeks Ago
Difficulty Level: 2
User Rated:Unrated
Symptoms
Many people think, that a weak turning signal lever is caused by hard rubber boot over the lever. It may be true to some degree, but main issue is worn tip inside the lever mechanism.
Name:	2020-03-17 17.18.40.jpg
On the right is 18 years old tip from a turn signal lever and on the left is new looking tip from a wipers lever.
These tips slide inside grooves, but when the tip is dull, it will not hold inside a groove and fall out easily.
Contents
<< <    Next Page: Getting the column out (Page 1 of 3)    >  >>
Comment
Search this Guide:
(T) Steering column switch wiring TpT 500 (Classic) 1 24-06-2019 13:48
(T) Steering column switch El1980 Bravo 12 05-04-2013 11:06
(T) steering column switch the joker Palio 11 30-01-2013 10:56
(T) steering column switch wish mine was orange Bravo 11 28-03-2012 20:40
(T) Indicator switch on steering column...? Bradley1984 Bravo / Brava 1 06-07-2009 22:36
