Tools You Will Need -ratchet, extension bar, 24mm socket, 10mm deep socket, 6mm allen key and a 3mm allen key
Disconnect the battery
PLEASE WAIT AT LEAST 20 MINUTES, AFTER DISCONNECTING THE BATTERY, BEFORE TOUCHING ANY AIRBAG CONNECTORS.
Turn your steering upside down to make it easier to access the 6mm allen screws
U can only get to the bottom one like this
So use the 10mm deep socket and extension to crack the bolt off easy, continue with the 2 other bolts located on the steering wheel.
After you have undone the screws slowly pull the horn/airbag away to reveal 2 clips (green and yellow)
Place 2 finger nails under the yellow tab and lift it should unclip do the same with the other one and simply pull the plugs off
Remove the black tab cover in the centre of the steering wheel and it will reveal a bolt (next pic) use your ratchet, extension and the 24mm socket to crack it off and unplug the horn clip and slip off the steering wheel
when attaching the new steering wheel make sure to like up the line on the wheel (yellow mark) with the mark on the center circle after that just reverse what you did and your done.
