Right i discovered this last night............if i pull a sharp u turn......at speed my oil light comes on. I did it once and heard a beep but didnt see what it was, so purposely did it again and it was the oil light! Any ideas on why?
Hellcat said:Oil level low and sloshing about under g-forces?
Wow, great thinking - you after some rep? :chin:custard boy said:seriously though,any hint of an oil light and the 1st thing you check is the oil level.
you know itStuart DemonD said:Wow, great thinking - you after some rep? :chin:
James M said:....get the bonnet up and check the dipstick!
StiloBoy said:Lights on the dash should be treated as too late lights! When the oil light finaly comes on it means you've knackered your engine! Oil light isn't a oil level indicator but a pressure light, and it'll be at something like 4lb.ft by which point the top of the engine will be shagged!
Some cars have a seperate oil level gauge, the Saxo VTS has one, problem is they are never as accurate as actually whipping out the dipstick and checking it with your own eye!
