Old 07-04-2019   #1
Trader Rating: 1
patches has donated!
Engine swap
I picked up a 1999 Punto Cabriolet about a year ago as my next project. The body is tatty, the roof terrible but mechanically it runs like a top and I love it!
While on eBay looking for random bits, I came across a 1.4 turbo from a 500 Abarth with the transmission included and wondered if it would be feasible/practical to swap it in. My initial thought it is too much power (160 hp version) for the chassis. I'm going to sort everything else first but I would welcome views about swapping in a bigger engine...and if so, which one?
1999 Punto Cabrio formerly a 2003 Barchetta and a 2001 Marea Weekend 2.0 HLX
patches is offline Reply With Quote Quote
Old 24-04-2019   #2
Croatia
Re: Engine swap
It has been done but tbh mk1 Punto doesn't have the strongest body let alone the carbio, you would need to swap everything. If you really want to do it more power to you but get body braces and make sure you have good breakes. Good luck in your advanture
Likes patches liked this post
AnteLo is offline Reply With Quote Quote
Old 29-04-2019   #3
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Skate Boarder Champion
Re: Engine swap
certainly doable, back in the day people dropped GT engines in cabbies no problem, around same torque but much much heavier.
If I got another mk1 i would defo tjet swap it without question.
Is your cabbie a 1.2 16v (85) or a 1.6 8v (90)? if you have a 1.2 then its a fire engine and so pretty much to get it in you'd just need to swap your engine mounts over to the tjet and it'd bolt up, not sure about the gearbox though, and driveshafts may not be the same length. I've not looked into the ins and outs of it but it should be a simple swap as far as engine swaps go.
One word of warning I do have is the modern tjets really need all their canbus body computers and dash cluster etc etc plugged in or it just wont work, this would be a challenge and a half to do, would also mean converting the throttle to fly-by-wire rather than cable. The alternative is aftermarket ecu.
So basically yes you can do that, its a simple-ish swap but not simple as bolt in and away you go. As above, its been done so your best shout is to do lots of searching and reading. All the fiats from this era are very similar if fire engined ones so dont just look for/talk to owners of tjet mk1s, tjet swapped cinq/sei and as far back as old pandas and uno's will have lots of relevant information.
Finn - Panda 100HP - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT, Panda Mania 1242 mpi
blu73 is offline Reply With Quote Quote
(T) swap 1600 cc engine for 1400 cc engine microe Punto (Mk1) 2 07-03-2018 10:45
(Tu) cinq engine swap but can't find engine valyboi Cinquecento / Seicento 28 31-08-2013 12:59
(G) Engine swap or head swap advice? Multiodd Multipla 6 10-01-2012 21:37
(T) Seicento engine swap... which engine? xjairusx Cinquecento / Seicento 11 11-05-2009 14:56
(G) engine swap to an punto gt engine boukekoppejan Cinquecento / Seicento 15 22-04-2009 13:57
