Check if your head is getting enough oil. If he rebuild the block without knowing what he was doing, he might placed the gasket the other way around, realised it to late, damaged that one lobe to low oil feed, replaced the gasket the proper way.
That's very interesting! If this is true, do you have any idea which valve and which cylinder will start complaining?
My problem is located at the valve ( I can't remember if it's intake or exhaust) of the third cylinder.
