FIAT Auto Specialist Team
Old 24-11-2017   #1
Croatia
Ignition switch positioning problem
Hello guys. I was replacing heater matrix on my Punto, got everything back and connected and for some reason my ignition switch started to behave strange, although I didn't touch it during the process.
When I turn ignition key ON, only headlights are working. All electronics are working somewhere in the middle, between OFF and ON, you really need to aim it. When you turn on the engine, only headlights are working. It could be due ignition switch mechanism or? But why now, suddenly, didn't even touch it. Maybe some other compontents are interfering with it, like steering wheel?
Thanks in advance.
VitaPepe is offline Reply With Quote Quote
Old 25-11-2017   #2
Croatia
Re: Ignition switch positioning problem
I received key code problem/failure in multiecuscan.
Old 26-11-2017   #3
Ireland
Sounds like the switch itself is faulty. did you disturb the back of the ignition barrel where all the wires go in?
digger58 is offline Reply With Quote Quote
Old 29-11-2017   #4
Croatia
Quote Originally Posted by digger58 View Post
No, just disconnected 2 connectors that goes in switch and that's it.
Should I get new switch with new keys and transfer my code to new key?
That would work? As shown in video:
Old 29-11-2017   #5
Ireland
Make sure the connectors are properly connected. Maybe a loose connection there.
Old 30-11-2017   #6
Croatia
When you stop key midway between ignition off and on, everything is working, so I guess connectors are properly connected.
Old 01-12-2017   #7
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Skate Boarder Champion
if it were me before anything else i'd disconnect -ve battery terminal, physically remove all the connectors you disturbed doing the heater matrix, within reason of course don't dismantle the whole car again, but any you can access without stripping panels inside. check they don't look corroded or dirty etc, put them all back again with extra care they are all firmly pushed in and clicked. reconnect battery and see if its sorted.... The old addage of have you tried turning it off and on again but applied to wires. Its most likely gonna do nothing but its worth checking before doing anything else imo.
Finn - Panda 100HP - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT, Panda Mania 1242 mpi
blu73 is offline Reply With Quote Quote
(T) Ignition switch problem, maybe? Alfredio Coupe 1 01-02-2017 18:23
(T) Ignition barrel switch problem stewart54 Ducato 0 05-07-2016 11:15
(T) Ignition Switch Electricial Starting Problem Jasper Happensprat Ducato 5 06-05-2016 18:31
(T) Possible Ignition Switch Problem? oboe123 Cinquecento / Seicento 6 08-07-2011 18:04
fiat punto ignition/steering lock and ignition switch ste21000 Auction Watch 7 20-03-2006 02:23
