Hey Forum, I'm new here so hopefully i can find the information from you lot of knowledged people!!!
I have a fiat Punto mk1
I recently changed my valve cover gasket and Oilpan with the help of a mechanic in my family, And since then my battery doesn't seem to be getting charged. Or at least the charge isn't getting through.
I have used a battery tester and the battery stays at 12.4v with the engine running when it should be approximatly 14v.
The the auxillary belt is running and the alternater turns over if i get the car started with a jump power unit. Is there anyway that i could have disturbed wires while changing the oil pan or what else could have happened with engine calibration.
Also since then i now have a (what looks like an injection) on the dashboard, To which i have researched as an ignition fail light..... that burns and if i press the accelerator pedal it seems to misfire, BUT the sparks are only a few months old and the problem wasnot there before my messing around.
I look forward to what answers or suggestions i might get, And would be very grateful from you all.
Thanks!!!
Dale.
Thanks!!!
Dale.
