W whitey Member Joined Nov 26, 2003 Messages 605 Points 110 Location edinburgh, scotland Nov 25, 2012 #1 can anyone please help me with the location of the relay for the rear window heater? i have a mk1 60s so have no relay/fuse board in the glovebox
fingers99 Patron member Parked in the garage Written a guide Joined Mar 20, 2006 Messages 27,743 Points 4,560 Location Liverpool Nov 25, 2012 #2 I'm not 100% sure that there is one. Is the fuse intact? Is the earth side of the circuit OK?
OP OP W whitey Member Joined Nov 26, 2003 Messages 605 Points 110 Location edinburgh, scotland Nov 25, 2012 #3 fuse is fine and earth is ok. i'm getting a reading on the voltmeter but not the 12 volts required so i just assumed it was a dodgey relay
fingers99 Patron member Parked in the garage Written a guide Joined Mar 20, 2006 Messages 27,743 Points 4,560 Location Liverpool Nov 25, 2012 #4 Usually relays will be on or off. I'd take the readings with the connectors off.
