i am getting an intermittant handbrake light on,i checked the handbrake switch and fluid levels and all is o.k
if i disconnect the fluid resevoir switch/sensor then all is fine and the handbrake light comes on/off correctly
does this mean the resevoir switch(float i guess) is sticking or faulty or would a problem with brake pads also show this sort of intermittant light
