fixitquick3
Hi, My punto has failed its MOT on 3 major points:
1. “Excessive catalyst emissions.” The paperwork shows hich co emissions Anyone know what’s causing this and how it can be remedied? How much should it cost? the MOT garage suggests replacing the air sensor - without any guarantees. Any comments?
2. Last year’s expensive garage fix was to replace worn radius arms and subframe assembly bushes. Its failed again due to the “subframe bushes incorrectly fitted” - the bushes should be on the bottom of the subframe and not the top!!! Can anyone advise?
Reading elsewhere it looks like the bushes should go on the bottom of the subframe with the open, “cup end,” upwards, touching the to the subframe? Can anyone confirm? Is this a quick/easy job – or will I have to go to that expensive garage? Suggested costs?
3. Finally, how easy is it to replace a front shock absorber?
Any advise would be welcome.
