oakld
- Apr 27, 2007
- 8
- 3
Hello,
I have a 1.2 Punto SX. When the engine is cold and you start it, often you can hear quite loud bubbling, which sounds like comming from the center of the dash board. Also, it seems to react on gas pedal (the more you press it, louder it is). It stopps when the engine is warm. The temperature meter, when reaches optimal temperature, it stays precicely there, indicating it's all right. However, the coolant level on the cold motor shows "MIN", while with warm motor the watter is pushed right to the top to the cap and if you open it, it overflows and leaks out for a while. It does this for a while, maybe 8 months, however service-check 6 moths ago was alright.
I was thinking the seal under the motor's head could be gone, but I'm not professional.
Any apparent reason for this? What I should request at service?
Regards,
Oak
Regards,
Oak
