FIAT Auto Specialist Team
Old 03-08-2013   #1
Trader Rating: 1
Exclamation ESP/Hill start problem?
Ive got a Punto Evo 1.6 multijet Sporting but the last few days the ESP/Hill start keeps turning its self off Has anyone any Ideas?? cheers
Bravo T-jet + Panda 4x4 Twin-air
quatermass is offline Reply With Quote Quote
Old 08-08-2013   #2
Trader Rating: 1
Unhappy Re: ESP/Hill start problem?
off the the dealers then
Old 09-08-2013   #3
Switzerland
If you don't have any OBD diag tool (like MultiECUScan) you have to go to dealer.
It is not possible to diagnose with a error light. This light just mean there is a problem with the module, than you have to read the module DTC to find a more precise error, and finally search it in the direction indicated.
Punto 2012 Easy - 1.4 8V 77CV - Blue
Mkala is offline Reply With Quote Quote
Old 14-08-2013   #4
Trader Rating: 1
Right! Back from the dealers, Good News/Bad news. I work at a garage so was able to check what error code came up "U1715". The Yaw sensor has gone duff so the next thing to do was check if the car has got any warrenty left. Yes it has! so I booked it in and yes they came up with the same fault and code and its covered....Result!!! BUT!.
Its within the 3 year warrenty BUT NOT the 60000 mile limit....bugger :0(
Its done 68000 so Ive rang Fiat up and told them and we'll see if we have any joy from them. Finger crossed.
Oh and its located near the gear stick/center console.
Old 14-08-2013   #5
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Quote Originally Posted by quatermass View Post
If its 2-3 years old then its a dealer warrenty not Fiat, if under 2 years then the mileage is unlimited I believe under the Fiat one.
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Qubo Dynamic Dualogic WAV & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 14-08-2013   #6
Switzerland
Thx for the update ! Hope they fix your car under warranty
Old 15-08-2013   #7
Trader Rating: 1
Exclamation Re: ESP/Hill start problem?
Ive only had the car a few months and i did not get it from a Fiat dealer hence the call to fiat. I must admit ive been having more problems with this car than any of my many other fiats ive owned.
1/ Loosing Coolant out of the EGR cover, had to buy new cover.
2/ESP/Hillstart/Traction Cont not working, needs new Yaw sensor (still in progress)
Last but not least The "Change Oil Warning Light" came on last night and yes its had an Oil change
TO MANY ELECTRONIC BULLMUCK GIZZMOS , I think I should of stuck to my trusty Panda.
Old 15-08-2013   #8
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Bet they didn't reset the oil degradation counter...
Likes quatermass liked this post
Massive gash
Just a little touch up
Old 15-08-2013   #9
Trader Rating: 1
Quote Originally Posted by Andy Monty View Post
I recon youre right
Old 16-08-2013   #10
Trader Rating: 2
I recon youre right
Which means it needs another oil change and the counter resetting ASAP!
Otherwise the DPF nightmare will begin also
Old 31-08-2013   #11
Trader Rating: 1
Another update of my esp/hillstart blah blah problems, no joy from Fiat, not covered by warranty thanks a bunch.So Im off to find my Yaw sensor (somewhere near the gear lever). Ive seen some on the BAy at least. The one thing Ive found with this Yaw/n sensor is that it works, as in when I park the car on the flat it sometimes works but my driveway is on a slant so I'm stuffed
Any way If you have a car over 3 years (mine is not) or over 60000 miles (mine was) you are stuffed!, after owning 10+ Fiats this has been the most trouble but still Ive got my Panda4x4 that rock and always will
Old 31-08-2013   #12
Trader Rating: 1
Sorted!
Old 02-09-2013   #13
I've just started getting esp/ hill hold unavailable light/error showing up every time I start my 1.4 sporting.. Trying to get my obd2 to find the error code. Have you sorted this problem then?
Allanmark is offline Reply With Quote Quote
Old 13-12-2013   #14
Trader Rating: 1
Sorry for the long delay. NO I did not get the job done under warrenty BUT Ive fixed the fault MYSELF!!, there was nothing wrong with the sensor at all, Just a broken wire on the plug going into the sensor.
The hand brake gator was catching on the plug of the Yaw sensor so If you have an EVO its a good thing to keep an eye on.
Ive since have sold the Evo but dont worry its be replaced with a Panda MJ 4x4 2013
Likes Most Easterly Pandas liked this post
(G) Hill Holer stadard with ESP?? aurick86 Bravo 10 18-03-2013 13:02
(T) Hill start problem Bluedoblo Doblo 0 28-01-2013 16:04
(T) ESP + Hill Holder pranksta Grande Punto 5 29-10-2009 10:45
(T) Hill holder and ESP unavailable Jazzy Jase Grande Punto 19 29-11-2008 21:12
(T) esp and hill holder marty27 Grande Punto 9 11-11-2008 14:48
