Disconnect - from battery
open upper alternator bolt 13mm
Remove the wheel and a protective case.
Raise the car as high as possible!
Pull yourself belt idler a second hand reset the belt! (13mm wrench)
Unscrew the bolt of pad (18mm).
Turn off the two cables. (8 and 13mm)
insert between gearbox and beam piece board
Wheel side unscrew the two bottom bolts (13mm).
Now you can pull out alternator.
Put new alternator or after rebuild :slayer:
assemble in reverse!
sorry for bad eng
Full version...
sorry for bad eng
Full version...
