Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Fixing sticky door handles<!-- google_ad_section_end -->
Stop having to tell your passenger "Push the handle down!"
Published by atom0007
10-04-2012
Difficulty Level: 3
User Rated:Unrated
Step 1
Remove door handle from car.
First remove door card. Then disconnect handle rod from door lock mechanism. Undo the two screws holding the door handle onto the door. Push handle out from inside to outside of door. This is covered in detail in other guides.
Step 2
Examine handle
Name:	2012-04-05 13.33.51.jpg
Name:	Annotated handle 1.jpg
Name:	Annotated handle 2.jpg
Handle is two moulded plastic parts. I'll call them handle (the part that goes up and down...) and backing plate (the part that is screwed to the door, two nut inserts).
You'll probably see two rusty pins, and a rusty spring. It's the rust that swells, and adds friction. This prevents the return spring from closing the handle.
When the door handle was made, the two parts were put in a jig, and two splined pins were used to hold the two parts together. The pin is splined in the backing plate, and smooth in the door handle. This forms the simple bearing - the pin rotates relative to the door handle.
This is the point to lubricate. It's very difficult to lubricate this properly from outside - that's why it's so hit and miss when spraying WD40 etc onto the handle.
Soak the pin, spring in release oil to remove the worst of the rust.
I found that soaking the handle for about 2 hours in release oil still did not cure it. I therefore drilled two holes in each round pin housing to allow oil to get right where it's needed. With a small enough sharp drill (~2mm), it's easy to pop a couple of holes in the pin housing.
On each housing, I drilled:
1. One at the round end.
2. I opened the handle out and from below, drilled another. This allows for lubrication with the door handle back on the car.
Don't use too big a drill, you still need the pins to keep the handle together!
Lubricating in these holes freed the handle pretty much instantly.
Likes Kathymel liked this post
Old 05-07-2013   #1
Wink Re: Fixing sticky door handles
I fixed my sticky door handles by using WD40 on them. Just spray at the joint on the door handle until WD40 comes out of the bottom of the door. Pull the handle up and down about 20 times whilst doing so and that should sort it out for a good while - no need for drilling etc.
Likes gerryhogan liked this post
yngprfsnl is offline Reply With Quote Quote
Old 07-07-2013   #2
atom0007 has donated!
I hope you don't think I removed the handle, then drilled it, then lubed it for fun?
Believe me, I tried plenty of times from outside, with quite a few "release oils", over a protracted period of time.
This guide is for those who hit a dead end with that approach....
atom0007 is offline Reply With Quote Quote
Old 08-07-2013   #3
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
im with Atom here my friend
When i sprayed and fitted a 2nd hand set to my punto
i didnt check they worked
And it had the Sticky handle problem
I tried just lubin it - nothing
you will need a little hole to allow it to flow in
Maybe drill and tap grease nipple in to force grease into joint
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Comment
Search this Guide:
(G) Fixing back door rattle. Zog Scudo 1 07-12-2010 21:18
(G) 52 1.2 3 door - Door handles don't work, door can't open m1chaels Stilo 11 13-09-2010 19:07
(G) Removing Stilo 3 Door Door handles reecurner3 Stilo 1 20-12-2009 23:51
(G) Fixing Mk1 door mirror? Phreaktwo Punto (Mk1) 2 17-02-2009 18:21
(G) Sticky door mirror shrek Ulysse 23 04-02-2005 13:27
