im Axle Specialists
Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Mk2 - My sidelights come on instead of my interior fan!!!<!-- google_ad_section_end -->
How to fix
Published by a1ant
27-11-2008
Unrated
User Rated:
Difficulty Level: 1
Hello,
A fairly common problem on the Punto Mk2 is the interior fan not working when the fan control nob is turned. If instead, your sidelights come on, then this guide is for you!!
This is a 10 min job to fix, and all you will require is a small peice of wire, a stanley knife or wire stripper, soldering iron and solder (optional).
First thing to do is to remove the felt cover at the top of the passenger footwell. This is done by pulling out the two plastic push fit clips
This will reveal the interior fan and motor assembly.
Look to the left of the fan/motor assembly, and you will see a black wiring multi-plug
With your wire cutter/stipper, stip away a small amount of the insulation on the black wire either side of the electrical multi-plug. Then, simply bridge the connector with your new peice of wire as below.
Make sure that you then use some shrink wrap or electrical tape to cover up the bare joints.
Test, and fingers crossed, problem solved!!
Hope that helps,
Alan
Old 27-11-2008   #1
Denmark
Re: Mk2 - My sidelights come on instead of my interior fan!!!
So basicly it comes down to bad ground in the connector?
Current Car: 2000 Mark 2 Punto 80bhp 1.9JTD, 190k Miles
Modifications: 107 bhp rolling road remap at 140k miles, single mass lightened flywheel & 350Nm clutch kit, lowered 35mm, blanked EGR return at the exhaust manifold, diy 125 psi compressor horn.
DanielR is offline Reply With Quote Quote
Old 27-11-2008   #2
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Hi mate,
Yes. It doesnt handle the load very well and normaly melts. There are several ways of going about fixing it, but the above is the most simple and quickest. You coould also make your own upgraded connector block if you so wished.
Alan
If you see a problem post, please click the report button
a1ant is offline Reply With Quote Quote
Old 27-11-2008   #3
Forum Moderator
T14086's Avatar
T14086 has donated!
people will still post up this question however good that there is somewhere to link their post to....beats going outside in cold with phone camera
Thanks snipit thanked for this post
Old 11-01-2009   #4
wondered why my heater wasnt working,looked today and its the same prob with the wire burning out, lovely job chaps yet again
snipit is offline Reply With Quote Quote
Old 03-02-2009   #5
What a star you are - all done and working fine.
THANK YOU.
Blue
BlueHuman is offline Reply With Quote Quote
Old 03-02-2009   #6
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Nice one
Alan
Old 16-02-2009   #7
razz435 has donated!
thanks worked fine !!!!!!!!!!!
razz435 is offline Reply With Quote Quote
Old 27-03-2009   #8
Could this also have an effect on my wipers?
As both seem not to work at the same time
firsteaston is offline Reply With Quote Quote
Old 30-04-2009   #9
Hi, I had this problem, I went under the passanger footwell and it seems a connector with blue wires had been disconnected... I simply went under with no experience or knowledge, not even read this properly...just looking a tthe pictures! and I saw it was unplugged!
GOOD work on the pictures and thanks for the advice...
Just to clarify how I fixed my problem...
A connector with blue wires had been disconnected on the back left hand side.. I reconnected it and bam the blowers are working!
:bang::whogives:
wildsm4n is offline Reply With Quote Quote
Old 01-05-2009   #10
wait, my problem was that the blowers where not working... I was redirected here from a topic with a different heading sorry for the confusion but still great work! HELPED me on a different subject
:bang::whogives:
Old 29-06-2009   #11
is this the same on 2000 1.2? cos the pics look slightly different to what mine looks like!
"I wanna live 'til I die, no more, no less" - Eddie Izzard
AndyCockerill is offline Reply With Quote Quote
Old 14-09-2009   #12
is this the same for a P reg mk1 as i curently have no heater fan or wipers thanks mark
mark1979 is offline Reply With Quote Quote
Old 03-12-2009   #13
heater blowers ???
alan, does this solution to the fan problem also work on the grande puto 56 plate as i've been having the same problem but not the side lights coming on, eddie hayden.
eddie hayden is offline Reply With Quote Quote
Old 15-12-2009   #14
Hello to all,
I have the same problem with my Fiat Punto 2003 16v.
The blower motor was intermittent - and now it stopped working.
The sidelights are working just fine.
I cold follow the steps described on this topic to fix it but the problem is that
i cant find the black wiring multi-plug. Is it possible that i don't have one ?
If it helps answering my question i can take some photos and post them here.
Many thanks in advance
zykl0n3 is offline Reply With Quote Quote
Comment
Search this Guide:
(G) Interior heater/fan not working!!! niamhh Punto (Mk1) 14 22-12-2012 18:46
(T) Squeaky Interior Fan lcdm Punto (Mk2/2b) 4 24-12-2007 16:36
(G) Interior Heater Fan littlericharduk Bravo / Brava 3 26-11-2007 09:05
(G) interior air fan jerry1.8hlx Bravo / Brava 2 02-10-2006 09:24
(T) Punto mk2 sidelights zoe.walters Punto (Mk2/2b) 2 05-03-2004 03:22
