basically for a while my brakes were squeaking, so the mechanic at my work changed the pads for me, but now the squeaking has come back, the pads have only done 1k, so I checked the fluid, which is quite low, could this be the problem with the squeaking??? Also, I wanted to double check before I put the fluid in, I looked at the diagram in the cars manual, and it says that the brake fluid resorvoir is in the middle of the engine, but mines seems to be just under the drivers window, in the book there is nothing there??? Is this def the brake fluid resorvoir...?? (1.28v)
thanks again
thanks again
