Hi guys i'm new here.
I have some problem with my GT3.
I've full power ONLY bettwen 2000 and 4000 rpm.
On cold start seem the car run on 3 cilynder, and it's smoking a bit (oil smoke...) I'm sure the turbo is leaking, i need to replace it i know.
The car has 200KMeter (around 125KMiles) i've it tested with examiner (i don't have it) and the test reported no error. (The ECU light on the dash is off for the record)
I'm a bit into electronics so i've started making my own tester very simple in fact i'll get signal from sensor and read them inside the car on multimeter (simple version, the true is a bit different).
My request is the follows:
I have seen a lot of scan tools for obd car, but someone know nothing about fiat diagnostic? what interface and software can I use? I realy cannot find anythink about Fiat 3 pin connector and related software.
Someone can point me in the right direction.
Next week i'll have my car inspected and i'll change spark, spark lead, and so on sould i tell them to try the fuel pump?
I'm in a dead end!!!:bang:
Thanks for your help
Hope you undestand my English...
--EDIT
OK first time here and first mistake...
I wanted to post on tech subforum, can a mod please move this tread in it's natural place... Thanks
--EDIT
