General Headrest Removal ?
tesscott6312
Hi guy's,
Just wondered if it's possible to remove the front headrests from a Mk.2B (2004) Sporting.
Had a little pull at the weekend :D (don't tell the wife) and they don't appear to remove. Unless of course I'm doing something wrong.
Look forward to hearing from you.
Regards, Scott
Front or rear? I think they're the same actually :eek: Look at the bottom of the stalk where it goes into the seat, there's some cheap plastic clips. You have to push and hold the clip in and give it a good tug. I remember the first time I did it it was stiff and took a while.
That last sentence sounds a bit rude :chin:
Trooper,
I haven't seen any clips at the base of the headrest stalks.
Mine is a Mk.2B Punto by the way which has push buttons on the side of the headrest.
