Hi, I'm preparing to replace my Punto's Timing Belt.
Haynes Manual says tension is about right when it can just be turned on longest stretch with finger & thumb 90 degrees. But Haynes also warns the tension should subsequently be checked by Fiat! If I'm going to get them to take off engine mounting and auxiliary belt just to get the Timing Belt covers off for them to be able to check the Timing Belt's tension... bit pointless me doing the job in the first place - may as well pay them to do the whole thing. :bang:
Or... am I being overconcerned about Haynes' warning. Do I really need to get Fiat to do their tension check with their special tool on my Punto's 8v FIRE engine? Or is the rough rule 90 degrees with finger and thumb good enough for it?
A similair query applies to the auxiliary belt...
btw I typed "Punto Timing Belt Tension Tool" into a search engine and see there's plenty outlets selling the Sealey kit, but it's for 16v engines.
