Old 09-05-2006   #1
Failed MOT!!
Just got my car back from the Garage, it Failed on Emmisions. The lambda reading was 1.05 instead of in the limits of 0.97 0 1.03. They have said that they cant tell what is causing the reading, so have advised me to put standard air box back on and standard back box. I have the standard air box but the problem is i havent got the old standard exhaust, the reason i changed the standard exhaust was beacause it was blowing.
They have quoted me £120 for a new exhaust.
If this doesnt sort the problem they said change the lambda sensors - quoting about £85.
Do these prices and explanations sound right or could there be a more simpler reason why the reading is high??
Sorry for essay!!!
Punto MK2 1.2 8v ELX - Steel Grey - 4" Jap Style Exhaust - Induction Kit - 16" OZ Super Turismo GT's -
- Tinted Rear Lights -
dolman17 is offline Reply With Quote Quote
Old 09-05-2006   #2
Re: Failed MOT!!
Just looked at some other threads!
The temp of the engine oil was 93 degrees.
Old 09-05-2006   #3
Re: Failed MOT!!
I had a cinq sporting with a sportex 3" tailpipe,and that failed the mot on emmisions,turns out with it having such a big bore it was sucking air in too,so giving a false reading,so the guy at the mot station covered the bore with a rag,with the emmisions pipe still in place,this making a genuine reading and it passed!
you dont say if you have a big bore backbox on or not,but if you have then its worth a go,i was so suprised when it happened to me,iand i wouldnt have believed anyone if they told me,but it really did work
it also seems like they are trying to get a bit of coin out of you too!!!
if they wont try it,take it elsewhere!
keep us posted!
life is the fabric of thought,woven into the loom of the mind
Mr_noir_1976 is offline Reply With Quote Quote
Old 09-05-2006   #4
Re: Failed MOT!!
Yes its a 4" Jap tailpipe. I will see what they say. Or i might take it to another garage.
Old 09-05-2006   #5
thefishdude has donated!
Balloony Champion, Bee Wars Champion, Submarine Champion
Re: Failed MOT!!
normally for an emision failure people on here including myslef will recoment a bottle of injector cleaner and a dam godo trhashing before the test making sure engine ius ncie and hot.
how ever lambda failure on test sounds different to me. the price for the lambda i would say is a lil high possible
2001 Punto sporting in sprint blue with 2 Mr Bump air freshners and a new clutch and flywheel mmmm
thefishdude is offline Reply With Quote Quote
Old 10-05-2006   #6
Re: Failed MOT!!
Ok so how much would it cost for a Lambda Sensor?
Tried searching but cant find anything about a price??
Old 10-05-2006   #7
Re: Failed MOT!! *UPDATE* :(
Driving from work this Lunch time! Sitting at traffic lights felt a vibration under the car didnt think much of it!
The lights go green n when i put my foot on the accleerator it sounds like a tank! Carry on driving untill i reach my road! Pulled over opened my door left the car running looked under the car and could see that where the exhuast meets the manifold it come loose.
Do you think this has something to do with my car failing its MOT? or is it a bit of an unlucky coincidence!!
Old 10-05-2006   #8
Portugal
In my opinion that can be or not unlucky coincidence, if the exhaust was slighty loose when they did the testing, it can affect the readings, you should get a second opinion about that failed emmisions log just to make sure everything is like they said.But its rather dumb they advise you to put the airbox, it will not make any difference in the lambda reading, even the standard backbox is a bit strange thats only advised when the rear backbox have a bore, normally they should see your injectors and combustion chambers, even real messed up spark plugs can change lambda readings.
[B][LEFT]__ Fiat [COLOR="SeaGreen"]Punto[/COLOR][COLOR="Red"] "Sport"[/COLOR][COLOR="SeaGreen"] (ELX)[/COLOR]:[/LEFT]
-> 1250cc / 16v / :worship: 95Hp
-> 120mph on straight road :cool: / 0 to 80mph in 10sec.
-> [COLOR="seagreen"]GREEN[/COLOR] Induction Filter :D / No Kat / [COLOR="Red"]Supersprint[/COLOR] Exhaust
-> [COLOR="RoyalBlue"]SplitFire[/COLOR] Spark Wires / [COLOR="Orange"]OMP[/COLOR] Stability Bar[/B] :thumb:
KoSmOs is offline Reply With Quote Quote
Old 10-05-2006   #9
Re: Failed MOT!!
Oh just found from my dad that the exhaust is not loose is has snapped off part way up the maifold!! How this has happened i do not know??
Old 10-05-2006   #10
Re: Failed MOT!!
sounds like that is why it fialed its mot. you will need a new manifold by sound of it
Old 11-05-2006   #11
Portugal
Re: Failed MOT!!
Quote Originally Posted by dolman17
After a replacement i believe you'll not have more failed lambda readings.
(G) MOT failed OZ Seicento Cinquecento / Seicento 9 26-04-2006 19:24
(G) Seicento failed mot GhostWKD Cinquecento / Seicento 7 11-01-2006 23:43
my car failed mot beau Lets Talk FIAT 8 12-01-2005 22:53
(G) My Cinq Failed The Mot :( cinqy Cinquecento / Seicento 9 31-12-2004 18:42
(T) MOT Retest Results........FAILED! mdsremos Cinquecento / Seicento 15 25-06-2004 22:10
