im Axle Specialists
Old 4 Days Ago   #16
Re: Fiat Punto 2002 1.2 8v won't rev past 3000rpm
Hi all, I did the self-adaptation reset and phonic wheel relearn yesterday but no improvement. The engine light is also flashing now because I can't get the revs up to 5000rpm to complete the reset. The revs seem to have dropped further over the last week, it now cuts out about 2500 initially but once the engine has warmed up it cuts out around 2000-2200. Crank sensor on order and I'll update this thread when it arrives, hopefully mid-week. I checked the part number and it matched up with the one I linked to with the wire attached (46774532).
PoorlyPunto is offline Reply With Quote Quote
Old 4 Days Ago   #17
varesecrazy has donated!
Have you removed the spark plugs for comparison?
Thats a very odd running condition isnt it
Likes PoorlyPunto liked this post
Old 4 Days Ago   #18
I haven't checked them since the RAC guy replaced them 2 weeks ago, should I? The problem definitely isn't making much sense to me, especially now there's no error codes being stored.
Old 4 Days Ago   #19
Quote Originally Posted by PoorlyPunto View Post
Enough petrol in tank?
jackwhoo is offline Reply With Quote Quote
Old 4 Days Ago   #20
Quote Originally Posted by jackwhoo View Post
Half a tank.
Likes jackwhoo liked this post
Old 4 Days Ago   #21
You COULD interpret the MIL only after throttle is applied as a misfire..
Detected by the Lambda sensor in the exhaust
And somewhere it is 'failsafeing' by limiting revs
Plugs are cheap to check
Line them up in the order they come out..
Look for differences in colour
Ideally post some pics on here
Old 4 Days Ago   #22
Quote Originally Posted by varesecrazy View Post
I'll check them in the week. I did originally have a misfire code but this hasn't come back since the plugs, HT leads and coil packs were replaced. To me it doesn't sound like it's misfiring, and it starts and idles smoothly.
There's a thread on this forum from a few years ago (here), the guy had the same problem and posted a video of what was happening (here).
It's doing exactly that, revs cut out, engine light flashes etc but I can't even get it to 4000rpm.
Old 4 Days Ago   #23
Half a tank.
Is it like
https://youtu.be/dlaD7xzOidQ
Someone else had this problem some time ago and when I suggested crank position sensor my suggestion was shot down by another member but it did turn out to be the crank position sensor.
I cannot say your problem is crank sensor but it could be and it is cheap and easy to replace.
Thanks PoorlyPunto thanked for this post
Likes Mike1alike liked this post
Old 4 Days Ago   #24
Is it like
Yes, but it seems more precise/timed than that. Cuts out at exactly the same point, in that video the limit seemed to fluctuate. I notice in one of the comments someone said it's crank sensor in response to another comment asking how to fix the problem, not the uploader of the video though. Fingers crossed!
Edit: just read the description, it was the crankshaft sensor!!
Edit 2: I should add that when I was looking at the 'parameters' section in Multiecuscan, the engine speed reading was bouncing from 0rpm to ~800rpm and seemed to be out of sync with the revs but I don't know if that was a lag/latency problem between the ECU and the ELM interface. Each time the revs cut out, phonic wheel status changed to "faulty" and returned to "OK" when I left it to idle.
Old 4 Days Ago   #25
The engine ecu picks up the engine rpm from the crank sensor.
Old 4 Days Ago   #26
That's why I'm hoping replacing it will solve the problem. It seems to make sense anyway. Need to get to the bottom of it by next week so I can return the unopened replacement ECU before I lose £120!
Likes jackwhoo, varesecrazy liked this post
Old 2 Days Ago   #27
*****FIXED*****
Hi all, just to update this thread, crankshaft position sensor arrived today and has solved the problem! Thank you @jackwhoo for suggesting the sensor and thanks to everyone else for your help. The mechanics I spoke to seemed to think the car wouldn't start if the crank sensor was faulty but this obviously wasn't the case!
Only problem now is I've not managed to get the engine light to stop flashing since the phonic wheel relearn. I did rev to 5000rpm 3 times but I think it might be because I didn't allow the engine to warm up until the fan kicked in?
Anyway, thanks again for the help. I'm sure I'll end up posting again soon because I've got a list of other things to sort out with the car, it's not had a service in over 10 years!
Andrew
Thanks jackwhoo thanked for this post
Likes jackwhoo, varesecrazy, Mike1alike liked this post
Old 2 Days Ago   #28
Romania
Yes, for the relearn you have to warm up the engine first, then do the sequence of 3 times 5000 RPM, keep it at least 3 seconds on 5000 RPM then stop the engine and start it again within 10 seconds.
Nice that you fixed it and nice it was a cheap and easy fix.
The car do not start, as the mechanics told you, when the crank sensor is faulty only when it is completely out and sends no signal. That way by recevieng no signal ECU is told that there is no movement on the crankshaft therefore gives no gas. But many times crank sensor does not go out completely and it just gives wrong readings by wich ECU injects fuel and of course, it is not optimal as it is related to the wrong readings. A common problem with crank sensor when faulty is that it works ok when cold and dosen't work when it gets hot and causes engine to stop. And as long it gives readings that are in range, although they are less than should be with a correct working sensor, ECU does not register any error like in your case Andrew. @jackwhoo Congrats, you were spot on with the diagnosis.
Mike1alike is offline Reply With Quote Quote
(T) 03 punto active sport 1.2 8v won't rev past 3.5k Venox Punto (Mk2/2b) 2 06-02-2016 21:32
(T) HELP! Punto 60 won't rev past 4k! ianweaver Punto (Mk1) 19 12-06-2013 19:19
(T) Doblo 1.9 SX JTD 2002 - Wont rev over 3000rpm tommyvb Doblo 11 25-03-2012 22:49
(T) Seicento won't rev past 3000rpm! davesei Cinquecento / Seicento 5 20-11-2011 20:59
(T) seicento won,t rev past 3000rpm big cheese Cinquecento / Seicento 34 02-02-2011 20:54
