stirkjames
Hi, My computer said passenger side airbag disable switch or circuit has a defect check for opens, shorts or weak connections.
I disconnected the battery for safety (wait half hour) pulled out the disable switch. Its on the end of the dashboard behind the passenger door.
The plug has a lug you press in disconnect. On the switch the two prongs the plug came off just need a little nudge to make a better contact with the plug, shove it back and switch off errors.
