All of a sudden my Punto 188 is cranking but not starting, not even a hint.
I was pointed out that mostly this may be due to a faulty crank or cam sensor.
Unplugged and removed these sensors and took readings with a multimeter at the connector side leading to ecu (refer to picture).
I did this to find the respective supply and ground pins of sensors (these are 3 pin sensors). In order for me to later test the sensors, I needed to know which are the ground and supply pins..
With key ignition switch in ON position, I got the those readings which do not look right to me for the crank sensor(top). I was expecting a 12v or 5v on one of the pins coming from the ecu supplying the sensor however there is only 1.5v on the red wire and 2.5v on the white wire!
Can someone shed some light on what is happening? Is there a problem with the ecu or what ?
Please help
Please help
