- Jun 27, 2017
- 88
- 35
Hi, well I had same problem as many. The grommet in the wiper linkage has worn and then dropped off. I ordered a new set of WIPEX ones and fitted as instructed but very disappointed when following the instructions that the central new grommet immediately cracked on fitting. Has anyone else had this issue. Then I had a thought as these grommets are only held in with cir-clips. Does anyone know where I can get replacement grommets as I can refurb the old pair and then when the new pair wears out I can just switch.
Thirdly I was thinking, does this issue only effect right hand drive PUNTOs. Am I correct in my thinking that this motor and linkage is actually for left hand drive cars, which they have just flipped over to use on right hand cars meaning when the linkage wears, they fall off as if the linkage lay on the pin the other way up, it would never fall off.
I have attached pictures. By the way I paid £22 for the set of WIPEX linkages, I would think the grommets would be pennies to buy if someone knows from where.
