P paul36 New member Joined Dec 4, 2018 Messages 48 Points 21 Dec 5, 2018 #1 Hi I have a Yuasa 12V 40Ah 360A SMF Battery is there a good enough battery for a 2005 1.2 mk2b punto is the 40ah enough? many thanks
Brendan W Patron member Joined Nov 23, 2005 Messages 3,038 Points 669 Location Wexford Dec 5, 2018 #2 Would think so yes, unless you have a lot of aftermarket load fitted. Our runs around quite happily on a 37Ah 330A. The little bit extra will do no harm. Keep all the connections clean and tight all the way back to the alternator.
Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,186 Dec 6, 2018 #3 Ive fitted a grande punto battery in mine..... Much bigger then a standard mk2 punto No issues Except i got a tray from scrappy and cut it up..... as size wise they are different Ziggy
