Old 09-11-2018   #1
Arrow Can i swap a 1.4 t-jet engine into a 1.2 8v mk2 punto?
Hi guys, i was wondering if it was possible to swap a 1.4 t-jet engine from a fiat grande punto into a mk2 1.2 8v punto chassis, and if so what i would need to make it run.
Also this car does not have to meet UK road laws as it will be a track car.
HJFLPuntoProject is offline Reply With Quote Quote
Old 09-11-2018   #2
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Re: Can i swap a 1.4 t-jet engine into a 1.2 8v mk2 punto?
How different is the 1.4 t-jet vs the 1.4 16v?
If there same engine - then its possible with parts cannon in thoery
The 1.2 8v brakes arent upto the task of a 1.4 wise... u defo would need to look at hgt... and swappin to a hgt rear axle for rear discs....
Ziggy
Thanks HJFLPuntoProject thanked for this post
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 09-11-2018   #3
Romania
Possible.
Look at this series of videos, they talk about clutches, motor mounts, and most things that might be necessary:
As for electrics, you will need the t-jet ecu, and all the sensors.
I'd just buy a Bravo t-jet, strip it and use that.
If you still want to put the drive train into the Punto buy a totaled Bravo/GP
aurick86 is offline Reply With Quote Quote
Old 15-01-2019   #4
Croatia
There has been a few HGT's swapped with 1.4 t-jet and it isn't similar at all to FIRE or 1.8 16v, lucky they have been in similar chasies so fraknestaining engine mounts and other things is quite possible
AnteLo is offline Reply With Quote Quote
Old 15-01-2019   #5
judderbar has donated!
Finland
Quote Originally Posted by AnteLo View Post
Fraknestaining? I might start using that!
judderbar is offline Reply With Quote Quote
Old 15-01-2019   #6
You're gonna need a car ~£500 and an engine at about the same if not more.
My guess would be you would need the t-jet gear box, ecu and all ancillaries, which can add up to a surprising amount of money to buy. would would likely need custom drive shafts, uprated brakes and uprated suspension all round.
you would need custom engine mounts, exhaust and may need to replace things that you've not thought about like the switch gear in the car, fuse boxes and wiring to get everything working and in tune.
Long gone are the days where you would just weld a bracket and fit any different engine to any car.
Essentially all you would keep is the shell and seat and steering wheel.
there is no point not doing the suspension and the brakes because you want to use it on a track so it needs to slow and go round corners.
you can buy a punto grande T jet on Ebay right now for £1800. Far easier and more cost effective to buy that,, and strip off every ounce of weight that isn't needed.
Maker and voice behind the YouTube channel PuntoHowTo 12k subscribers canít be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is offline Reply With Quote Quote
Old 15-01-2019   #7
Croatia
Yeah it's much easier to get a doner car, well you can't find them for that cheap where I live. They usually go for +5000£
(Tu) Mk2 punto engine swap Tyy Punto (Mk2/2b) 4 18-04-2016 10:56
help 1.2 16 mk2 punto engine swap into my fiat cinquecento pancakeman Tech Talk 1 24-11-2013 19:30
(T) cinquecento engine swap punto mk2 1.2 16v kvonk Cinquecento / Seicento 22 24-01-2013 08:23
(Tu) punto mk2 engine swap..ideas plz veepunto Punto (Mk2/2b) 0 31-05-2009 22:11
