Thread Tools
Old 10-10-2018   #1
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Removing a diff locking retaining pin
So i did see this pin on my diffs... it locks the shaft holding the sun / plannet gears
Its not a hex / or torxs
It like a bit of metal folded over....
How the hell do you get the thing out....
Im looking to get a 2nd diff to repair my current box...
Item 5 in picture
ZiggyClick image for larger version
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 10-10-2018   #2
Re: Removing a diff locking retaining pin
Looks like a Roll Pin. aka a Spring pin https://en.wikipedia.org/wiki/Spring_pin
Normally you can get these out with a Punch, did find an easy way to remove these on youtube
Scudmonkey is offline Reply With Quote Quote
Old 11-10-2018   #3
judderbar has donated!
Finland
Quote Originally Posted by Scudmonkey View Post
Googling the part number shows it is a coiled spring pin
judderbar is offline Reply With Quote Quote
Old 11-10-2018   #4
Trader Rating: 1
portland_bill has donated!
These are known as roll pins. Spring steel, tight in their hole, so hold themselves in.
To remove or replace, need a parallel punch of same diameter as the hole, or as close as possible. Too small and it will tend to jam in the centre of the pin, making things worse.
Support the opposite side and tap the punch firmly with hammer. A small hammer is usually enough.
Never re-use. Always replace with a new one.
13 years motor trade, 16 years motor industry. 14 years Driving Instructor & 7 years Fleet Trainer
Panda Alessi
portland_bill is offline Reply With Quote Quote
Old 11-10-2018   #5
This is whats weird...
There is NO hole the other side to punch it out with.... 1way street.....
Ill get piks when i can
Currently fitted a donor box and its not the best..... so need to get a move and find another....
Ziggy
Meet Bumble-Bee
Old 11-10-2018   #6
Trader Rating: 1
Quote Originally Posted by Ziggy122 View Post
Ziggy
Always a pain when a rollpin is in a blind hole. Need to get something into the centre of it, to grip and drag it out, but that is difficult as it is a hardened steel pin. An eezi-out is usually too wide a taper. A self-tapping screw can work, if you can find the right one, whatever that might look like. Anything too tight will try to spread the pin and make it grip more, not tight enough and it won't grip.
Good luck with that. Much swearing and many tears are likely.
Panda Alessi
Old 11-10-2018   #7
Ziggy
Typical Fiat LOL Make something easy into something difficult
Old 12-10-2018   #8
Finland
Is the other hole hidden by the large drive wheel?
Otherwise I found a few methods that are claimed to work for small spring pins in blind holes,
The simplest is to hydraulically force it out by getting some stiff strong wire like piano wire or some alternative round thin object that will fit into the opening. Fill the whole with thick paste or grease or clay and hydraulically force it out by hammering the wire into the hole.
Then you get into tiny taps and screws and slide hammering it out, or welding something to the end of it and slide hammering it out.
Old 13-10-2018   #9
When i get 5 and dry weather ill get some pickys
Meet Bumble-Bee
Old 25-10-2018   #10
Did you ever manage to get the Pin out ?
Old 14-12-2018   #11
So some time later (2months)
Drilling is the only option
The you have to smash the main pin out to break the last bit off
You cant force it without weakening it
Ziggy
Meet Bumble-Bee
Old 14-02-2019   #12
Finland
Ziggy
https://www.docdroid.net/dV4MutG/fia...al.pdf#page=39
I just found this fiat c514.5 repair manual. Believe it or not the recommended procedure to remove that pin is to crack the differential carrier using a chisel at the other side of the pin and then punch it through!
They also have a procedure to check the differential bearing preload which would have to be a must if you are changing differential carriers.
Old 14-02-2019   #13
Quote Originally Posted by judderbar View Post
I just found a fiat c514.5 repair manual. Believe it or not the recommended procedure to remove that pin is to crack the differential carrier using a chisel at the other side of the pin and then punch it through!
I just dont know how to upload the PDF or were to put it as it applies to about 6? cars.
Drillin it was a bitch.... i did wonder about back drilling tbh....
But cracking it.... no no no.... that will cause problems elsewhere i can see it...
Ziggy
Meet Bumble-Bee
Old 14-02-2019   #14
Finland
Ziggy
I found a free PDF version. https://www.docdroid.net/dV4MutG/fia...al.pdf#page=39
The instructions are on fiat page 28 which is electronic page 30 of the PDF
Thread Tools
(T) crank locking pin hole notsmartcars Panda 1 29-06-2013 07:56
(T) removing inner cv joint from diff ?? sbyers10 Punto (Mk2/2b) 1 21-08-2009 14:43
Removing the door pin Ryan FIAT Boo Archives 2 17-05-2007 01:30
(G) 4x4 - No locking diff in the UK? PekingPanda Panda 4 27-04-2007 17:11
