Well I have a Fiat punto mk2 2002 70,000miles with a 1.9DS Engine
I would like to make a small turbo for efficiency do i need to change some things like valve spring or piston rings?
I don't want to cause damages to the engine I want to play it safe
Things I changed so far:
engine and gearbox mountings,
tripods,
cleaned the breather blockage from the cap of the engine,
new heater plugs,
changed gearbox fluid,
engine oil,
radiator coolant,
new handbrake mechanism (drums)
break pads,
changed a CV joint,
new set alloy rims,
wheel balance,
wheel alignment
tripods,
new heater plugs,
engine oil,
radiator coolant,
break pads,
changed a CV joint,
new set alloy rims,
wheel balance,
wheel alignment
