- Aug 15, 2013
- 457
- 165
Hi guys,
I've seen a few threads about fitting DRLs and thought I'd get me a set.
I bought these DRLs:
http://www.ebay.co.uk/itm/2x12V-9-L...ggy-Day-Driving-Lamp-lamps-White/272792113100
And one of these controllers:
http://www.ebay.co.uk/itm/Automatic...Relay-Harness-DRL-Control-Dimmer/162430543896
The DRLs were easy peasy to fit, they fit nicely in between the slots in the bumper (I've a bog standard active). You just need to drill 3 holes, one for the wire and one for each of the screws.
The DRL controller connects straight to the battery and has three wires coming out of it (apart from the battery connections). A red, black and a white one. The red and white are the connections to the DRL and the white one goes to the sidelight or dipped beam positive so that the DRLs can dim when the lights are on.
I've not connected that one up, my DRLs are on all the time.
Here are the DRLs close up:
Driverside:
Passenger side
Driverside:
Passenger side
