nickpaokgr
- Jun 8, 2017
- 24
- 13
Hi, I m new to the forum. Yesterday I ve noticed something strange,when I turned the car on everything was ok, all the lights on the dash turned off, while driving i saw the key code (immobiliser) light on, because i was afraid , i didnt want the car to stop in the traffic, i pulled over , i ve turned it off and on again and it was ok after that. This thing happened two times the past two days. The light wasn't flickering it just stood there on.
So do you know what may cause the problem? Also the most important thing is , If the light turns on again (while driving and not when i try to start the engine) after some meters will the car turn off by it's self ? If yes, after how many meters?Moreover, if it turns off while driving , will i be able to ignite it right away?Or i have to wait some minutes. If i connect an OBD will it show some error code with more specific details about the problem?
PS1. when i pulled over and turned it off and on , i didnt pull the key out, i just turned it off and on and everything worked fine.
PS2.Because i bought it from someone else, i dont have a secondary key nor the card with the key code, i was about to go and make a copy of the key these days. Is there any way that might be the key problematic ?
i have a fiat punto mk2 8v 188a4
I would really appreciate if you could help me.
thanks in advance.
thanks in advance.
