Old 01-06-2017   #1
Ireland
Cam Sensor and Crank Sensor - Sensor Type?
Hi all, I have a mk2 punto 8v. I am making a DIY tachometer. I have it working off the trigger to the coil pack but the result is laggy and inaccurate. I am now hoping to get a signal off either the cam sensor or the crack sensor. Does anyone know what type of sensors they are, and what kind of signals they produce? Thanks, Conor
conors891 is offline Reply With Quote Quote
Old 02-06-2017   #2
judderbar has donated!
Finland
Re: Cam Sensor and Crank Sensor - Sensor Type?
Quote Originally Posted by conors891 View Post
If you have a two wire sensor coming from your crank sensor it produces a very good square wave by following the shape of the notched crankshaft wheel. You can drive an LED off that signal to test your sensor. The two wire sensors are just a a coil of wire wrapped around a magnet.
https://www.fiatforum.com/punto-ii/4...ensor-ecu.html
judderbar is offline Reply With Quote Quote
Old 02-06-2017   #3
Ireland
It's actually a 3 wire sensor. Red, black, and white. Presumably Vcc, GND, and signal.
Old 02-06-2017   #4
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
So u wanna have a rev counter.... basically?
Fit an up spec dash instead?
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 02-06-2017   #5
Ireland
Thanks for the response Ziggy. Not looking to replace my current dash. What I have is an arduino (DIY programmable computer) and a small LCD screen. It displays the revs on the LCD. The arduino likes a nice clean 5v signal to work properly.
So I need to work out what kind of signal the crank sensor produces (I don't have an oscilloscope to check for myself). It would be ideal if it was a 5v square wave which, I believe, is what hall effect sensors produce, if it is a hall effect sensor. Thanks
Old 02-06-2017   #6
Never really looked at the waveforms on them tbh....
But the phlonic wheel where the crank gets its signal isnt stepped toothed its got a curve on them
Something tells me it wont be a square waveform but more of an ac waveform
With the flattened notch to dictate tdc
Ziggy
Meet Bumble-Bee
Old 02-06-2017   #7
Ireland
On a separate note, when the ECU detects it's at tdc from the crank sensor how does the ECU know that cylinder 1 is at the top of its intake stroke rather then power stroke?
Old 02-06-2017   #8
Cam ans crank correlation
The cam shaft has a sensor lobe on it
When crank tdc is picked up
It uses the cam to tell whicj cylinder
Bearing in mind ths punto uses waste spark system, so regardless if no1 is on exhaust it still gets a spark cause no4 is tdc
Ziggy
Meet Bumble-Bee
Old 15-06-2017   #9
Ireland
3 wires coming from crank sensor, red, white and black. Measured from a DC multimeter, when the engine is on, red is at 1.44 V, white is at 2.05 V and black is ground. The 2.05 does not change at all with RPM. Really need to invest in an oscilloscope to figure out what's actually going on.
What kind of singal do the fuel injectors get? Would I be able to get an RPM signal from it?
Thanks, Conor
Old 15-06-2017   #10
Moderator
g8rpi's Avatar
g8rpi has donated!
Hi Connor,
Normally the 3 wire sensors are hall effect type with a 5V supply. Not too sure why you are only seeing 2.05V supply, but it sounds like there may be a ground issue. Where are you connecting the meter common?
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 15-06-2017   #11
Ireland
Thanks for the reply. Yes I expected 5v too. Perhaps not a hall effect sensor? I tried with the meter common connected to the negative of battery​ and black wire to sensor. Got the same result in both cases
(T) crank and cam position sensor rockotansky Punto (Mk2/2b) 2 21-10-2016 17:28
(T) Cam/Crank sensor ruijc Punto (Mk2/2b) 5 15-04-2015 21:11
(T) Cam sensor non cam sensor type Doncasterlouis Punto (Mk2/2b) 6 08-01-2014 21:47
(T) Crank Sensor Type Todger182 Cinquecento / Seicento 5 31-07-2012 00:53
(T) Crank Sensor And Cam Sensor bode Punto (Mk2/2b) 4 28-12-2011 11:23
