Ok so just replaced the complete exhaust system on my nieces 1.2 Punto Active (54 plate).
A simple job apart from where the system joins the down pipe flange. I was surprised to find the nuts were 12mm AF rather than the expected 13mm AF, plus when I went to replace the nuts with new ones I found the threads were not the standard 8x1.25mm.
So where do I get replacement nuts or do most people just drift out the spot welded studs & replace the whole lot with standard size (M8x1.25mm) bolts & nuts?
