Frosty12345
- Dec 13, 2015
- 5
- 1
Hi, I had my punto for a few years now. Yesterday the temperature gauge seemed quite low after about a 1h run. Then the check engine light came on.
A few days before I noticed that the heater wasn't blowing quite as hot as it used to, mpg seemed a bit lower than usual too (about 49mpg instead of the usual 51).
Anyway, I checked the coolant and it was at the min level. I have topped it up for now but plan a full change soon.
When I came to the car this morning the check engine light was switched off, but the temperature gauge still seemed low. On the 1h drive this morning it seemed to take at least 20min to reach anything near the mid point on the temp dial.
I checked the fault codes; and p0113 (or possibly p0115- I can't quite remember) was stored.
On my drive home tonight it took a while (over 20 min) to get to about 35% on the temp dial. But after about 15min of stop start traffic it did reach the mid marker like it used to. Diagnostics said the coolant got to about 90degrees.
Anyway, my question;
Is it possible that all this is because the coolant was low, there was an airlock and this meant that the temperature couldn't regulate properly. do I just need to properly bleed the system?
Or
Is the thermostat on the blink and needs replacing? (If I order this from halfords (or euro car parts) (Circoli Thermostat 209650180) is that and a spanner all I need?
Ps, I found a guide about bleeding the system but it seems to refer to mk1, and squeezing the pipes. Is there a guide for 54 plate?
Thanks very much
Or
Thanks very much
