I just acquired a Punto 1.2 8v Active (2004). There's a few queries I'd like to ask about.
1) The airbag light is on, think this is due to the passenger airbag being turned off. The ignition key won't work to turn it back on. How do I go about turning it on, buying a new key? If so, how much is that likely to set me back?
2) The oddometer/clock is flashing when the engine is on. I've read this is to do with the CAT system and needs a 'proxy alignment', but could be the battery on it's way out. Would I be able to carry out a proxy aligment myself using something like Multi ECU Scan or no? If not how much would it cost roughly in a garage?
3)When I fill the car with fuel it stops every few seconds and so takes a really long time to fill. From what I've read it's something to do with the anti-syphoning system. Is there any way to fix this or do I have to live with it?
Cheers in advance.
Cheers in advance.
