jim whitehead
- I am trying to replace rear brake cylinders, which activate the brake shoes. (The bleed nipples are completely seized) The cylinders are bolted on by two small bolts into the hub and the cylinder is attached to the brake pipe by a 10mm nut.
- When trying to release the pipe union from the cylinder the pipe begins to bend. I think the bolt should move up the pipe thus releasing the union.
- I have used loads of lube and brake spanners...
thanks,
jim
