Hi, at the start of the week the amber engine warning light came on, I read the fault code and it was P0130, which after some research i found out was the pre-cat lambda sensor.
I changed the sensor, cleared the fault and everything was fine....for 3 days. Now on the way home from work the amber light has come on again this time with fault code P0135. Which I believe is also related to the pre-cat lambda sensor.
Does anybody have any ideas?
BTW it's a 2004 1.2 8v punto
