Old 14-07-2005   #1
Israel
something weird
recently i've noticed something weird in my punto mk1
while i'm driving 60 Kph the speedometer showes around 80.
how can i fix it ?
I'm sorry for my English, i'm learning
looking for some repair & manual book of punto Mk1 1.2 96'
asbit is offline Reply With Quote Quote
Old 14-07-2005   #2
Israel
Re: something weird
anybody ? . . .
Old 14-07-2005   #3
Re: something weired
have you put bigger alloys on ?
1998 PHASE 2 PEUGEOT 306 IN BLAZE YELLOW
marky23 is offline Reply With Quote Quote
Old 14-07-2005   #4
Israel
Re: something weird
no, I didn't. I'm Using The original 14"
Old 14-07-2005   #5
sounds strange if you have still got the original wheels on, i am sure someone on here will read this who might know what the problem is
Old 14-07-2005   #6
could be a number of faults. could be a bad earth or a incorrect feed to the transducer. It could be the tranducer. But i suspect the dash clocks could be faulty. Replaced these before for the same fault. p.s What are you checking it against, that may be faulty.
F.I.A.T. -- Flipping , Italian , Automobile , Tat . :)
FiatExpert is offline Reply With Quote Quote
Old 15-07-2005   #7
Israel
well, first of all, i've chacke it against my freind with a new Passat.
now, what you saying is that i should first replace the dash clock?
and then check the transducer? what is it anyway? (don't know the word).
could you please explain its job?
Old 15-07-2005   #8
Israel
Re: something weird
well . . . what is the transducer
and whre can iget dash clock?, mine is whithout revs clock or temp clock (for the temp its only a lamp)
Old 16-07-2005   #9
Israel
and I have another question.
which are the most recommended spark-plugs for punto mk1 1.2 mpi 96'?
Old 16-07-2005   #10
Israel
should I open another threaD?
Old 16-07-2005   #11
Trader Rating: 16
beau has donated!
Quote Originally Posted by asbit
if you want, might get more replies
Maserati 3200 GT Coupe
beau is offline Reply With Quote Quote
Old 17-07-2005   #12
Israel
well. we should return to this problem and solve it
suggestions?
Old 17-07-2005   #13
The transducer is what sits on the back of the gearbox. This is turned by the gearbox and then that componet gives the signal out the dashboard clocks.The dashboard clocks then recieve this signal and move the speedo. Either i would get from a scrap yard. The dash clocks new are not cheap. REMEMBER this is what i think, it could be the wiring to the transducer as said before or between the clocks.
Old 02-09-2005   #14
Israel
TNX Ex I think you right, the problem is that in israel its not easy to find a punto in scrap yard. hope i will.
asaf
Teddy Bear alloy wheels weired :s dave Auction Watch 11 17-12-2004 19:34
weired dave Leisure Lounge 0 29-10-2004 01:21
