I've searched the forums and found someone who had the same problem I'm having right now. The post is here: fiatforum.com/punto-ii/39329-abs-activating-low-speed-light-braking.html. (can't post URLs)
There was a problem with the abs about 6 months ago. At that time the ABS-light was glowing on the dashboard, the pump kicked in at low speeds, and I could also hear the pump running a few seconds each time I used the brake. The shop we used tried to replace one of the sensors at the front wheels (can't remember which) as this was indicated by the OBD reader. This didn't fix the problem, so we sent it to the local Fiat dealer where they fixed the problem. I don't know what it was since it's not my car, and I didn't ask the mechanic.
Now the same problem occurs. The difference is that the abs kicks in as soon as I touch the brake pedal and no light is indicating that it kicks in or that there's a fault in the system. Also, I'm not able to hear the pump turn on. I've tried to take out the fuse for the ABS, and then the light for the handbrake and the ABS comes on, but it brakes smooth as silk.
What I want to know is if there is a relay for the ABS that has gone bad. I've heard that these can lock up in the on-position (if the car has got one), making the pump run all the time. There's a big relay in the center (which I've seen in the Punto I've got). Is this for the ABS? i188.photobucket.com/albums/z317/SCOOBYT_2007/DSC00170copy.jpg (Would provide link to picture of fuse-box, but I can't post URLs)
I saw in the post I linked to at the top that the target coating on the bearing hub had disappeared and that's what caused it, but is there something else I can try first? And if there isn't, is there some problems that can occur if I take out the ABS fuse till the owner can get it fixed? I know the ABS won't work of course.
