Hi all,
I beg your experience and knowledge in Mechanical / Electronic to help me solve a problem on my Fiat Punto which has only 93000 km. Note that the injection pump is a pump Lucas (electronic).
I explain my problem:
The car will not start if I'm speeding by starting at high revs. If I raise the foot, the car stalls. I just roll with it, but every time I let go of the accelerator pedal, the car will stall (at low speed). LED lights (injection) by intermitance irregularly but especially when I loose the accelerator pedal.
It grazes slightly when the engine is running.
Note that the fuel pump is not clogged. Against by the fuel filter is not filled with diesel. The mecano to help me solve the problem try to fill a syringe to see if it starts better, but empty it quickly and say that it is not powered or improperly fed.
Thank you very much for your help, the vehicle rolls over now, waiting to solve the problem.
