Old 03-05-2012   #1
Belgium
punto mk2 1,4 16V Drainage bolt oil leak
Today i changed the engine oil of my punto by my own. Unfortunatelly i overstressed the drainage bolt a little bit and now comes to a tight point but it still continues to turn. After 5 hours (in which i used the car for 1 hour) i saw a small drop just under this bolt (not fallen on the ground). Before i put the bolt i added 3 rings thinking that it sould stop the turn. Do you have any ideas what to do to stop the oil drops? Is it going to become worse? cause i can live with such a small leak.
chris lar1968 is offline Reply With Quote Quote
Old 03-05-2012   #2
atom0007 has donated!
Re: punto mk2 1,4 16V Drainage bolt oil leak
ok, new thread!
I don't know what the rings are you're talking about.
how are you going to get the plug out for the next oil change?
atom0007 is offline Reply With Quote Quote
Old 03-05-2012   #3
Burkina Faso (Upper Volta)
Quote Originally Posted by atom0007 View Post
ok, new thread!
i think he means 3 washers
chris lar1968 if you take the bolt out again it might bring all the stripped thread out with it and not work at all
however if it didnt you could try re nipping it with some ptfe tape on the thread
only other alternative is to have an insert fitted into the hole but a garage with this equipment would have to be found
last alternative is a new sump
s and b is offline Reply With Quote Quote
Old 03-05-2012   #4
Your options seem to be
1. Thread repair as suggested (Helicoil or like)
2. Packing out the sump plug like S and B suggested to get the plug to tighten.
3. New sump
4. Some kind of sealant that you would have to remove every time you do an oil change
You can live with any oil leak as long as you can add oil faster than it leaks out . But it might be an MOT fail (or your country equivalent).
btw, there is no need to really tighten that bolt up, it's only an oil seal. Bit late for that now though...
Old 04-05-2012   #5
Trader Rating: 5
fingers99 has donated!
I'd suggest you pull the sump, get an insert made up of aluminium and get it TIG welded in place. Won't be that much cheaper than a new sump, but will probably last longer.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 04-05-2012   #6
Belgium
Thank you very much for your responses. They are very usefull, propably i will take my car to a work shop and i'll ask to fix it with an insert. I wonder the oil sump is from aluminium or iron? cause if it is the first fixing won't work.
Old 04-05-2012   #7
Trader Rating: 5
Should be aluminium.
M12 fund 20
(T) Oil leak 16v Jonnybobs Punto (Mk2/2b) 2 02-03-2012 20:08
(G) Mk2 punto rocker cover oil leak johnsoncarper Punto (Mk2/2b) 4 31-12-2009 08:48
(T) Mk2 punto whining noise and oil leak Tony123 Punto (Mk2/2b) 0 16-06-2009 22:52
(T) mk2 punto oil leak Rockett Punto (Mk2/2b) 10 10-03-2007 21:17
(T) Mk 2 Sump Bolt Drainage Key tommyh Punto (Mk2/2b) 3 08-07-2006 19:15
