![]() | #1 | ||
Posts: 6 Thanks: 0 Trader Rating: 0 | Direction Indicator Relay Can someone tell me where the direction indicator relay is situated on the 1.2ELX Punto. (It's NOT one of the 4 relays next to the fuses behind the recess on the driver's side) Taking these out doesn't stop the flashers. Malcolm
![]() | #2 | ||
Posts: 635 Thanks: 0 Trader Rating: 0 | Open the glove compartment, look at the top of it, twist the catch and swing the flap down. Ta da! relays.
![]() | #3 | ||
Posts: 6 Thanks: 0 Trader Rating: 0 | Thanks Evil, but there is no flap inside my passenger's glove compartment, probably because the airbag is fitted over it and there's no room. The ticking from the relay is definitely coming from the right side of the steering wheel (RHD version) but there is no sign of it. Malcolm.
![]() | #4 | ||
Posts: 83,462 Thanks: 1478 Trader Rating: 10 ![]() | Don't know if this is the one but i took dash out of a punto the other day (mk1)and under the bottom cover of the stering colum is a blue relay!
![]() | #5 | ||
Posts: 6 Thanks: 0 Trader Rating: 0 | Thanks Dave! I've never found so many relays at once. Every colour except blue. I must have a different model. We are talking about a Punto. Has anyone else got any suggestions please? Shall I look in the gear box ?
![]() | #6 | ||
Join Date: Sep 2003 Location: middlesbrough, United Kingdom.
Posts: 2 Thanks: 0 Trader Rating: 0 | Indicator relay is under the steering wheel column, remove the cowl, pull it out, try indicators, if they don't work you definatley know its the right relay
![]() | yoggod | Bravo / Brava | 3 | 15-12-2003 00:43 |
![]() | Malcolm7 | Punto (Mk2/2b) | 4 | 26-07-2003 19:01 |
