Hi all, i've recently bought a 2000 1.2 8v punto with 70k on the clocks, but i'm having a strange problem with it.
The car starts and runs lovely, but as soon as i try to rev over 4k, it misfires as though theres no fuel/spark. drop the revs and its perfect again.
I gave it a full service, still same. connected it to obd but that shows no faults. No management light on dash either. When running live data, at 4k it shows no signal to coil packs, so i replaced them both - still the same. I checked the timing and wasn't happy that the marks were dead on, so i replaced the belt. Lines up perfectly. Phonic wheel is bolted on in the correct place. Still the same!
Started to think the manicat may be blocked so i slackened the manifold bolts and pulled it half inch from head to let gases out. no different.
Has anybody else had this problem and solved it? I've read through the forums but no one seems to have posted a solution and what worked for them. Any help would be much appreciated.
Thanks.
Thanks.
