cgarr04
Hi guys,
I'm a new 'R' driver with a late 2002 Punto Active 1.2 8v. The car was purchased with 79000 miles on the clock and has both MOT and TAX certs going back to early 2007. It had 3 previous owners from new and was driven by an old woman previously, so I know the car has been maintained fairly well and is road worthy.
I'm not sure if i'm just getting familiar with the cars performance or if the performance is slowly getting worse.
When I first bought it, it was surprisingly quick however the MPG was quite poor. This improved dramatically when I adjusted the tyre pressure to 30/31 PSI from about 27/20(!). The car was also low on oil at purchase so I got 5L of 10w/40 part synth oil and added about 1/3rd of that, also topping up coolant, washer fluids and checking the air filter condition whilst I was at it. The filter is fairly clean as is the oil, it's quite clear however both could do with a change in a month or two probably which I intend to do.
I done a 80mile round trip on tuesday and if memory is correct it used about 1/5 of a tank of fuel and the computer said I was averaging 49mpg. I was generally doing 60-80mph (90mph peak) on a straight straight dual carriageway the entire journey. Does this sound about right? (I know i'm an R driver but I believe sticking to 45mph is more of a hazard than me sticking to the speed limit of the road 2bh.
The car has no problem reaching its max speed of 95mph however it's the length of time it takes that concerns me. For example, changing into a faster lane on the motorway and overtaking someone doing 30mph in 3rd gear is a major risk. I feel like i'd need to drop into 2nd in order to get the power to perform the task but then you get that "kangaroo" effect. Basically I can shift into 3rd at 25mph and floor it and it would take maybe 20-30 secs before it would reach 50mph, with my foot to the floor.
If this seems unusual, can anyone advise on steps to check/restore/improve performance? I was tempted to buy some redex to see if this has had any effect? Ive also driven it like I stole it, hitting the injectors in 2nd @ 60mph,albeit after having it floored for about a minute, but it made little to no improvement.
Also the brake fluid light and handbrake (!) light will flash on occasion for a split second and I was just wondering how I could check this for a dodgy earth/wiring etc?
I appreciate that there is probably only about 50hp by now under the hood, but i'm unsure if there is an issue present or wether i'm just craving more horsepowers?
Grateful for any advice given.
Thank you!
Thank you!
