dawozere
Member
Right, I need to bleed the brakes as there is definately a lot of air in it, whats the right process?
I've been told this:
1. Start Engine
2. Open Master Cylinder
3. Make sure its full
4. Start at back passenger side wheel, get assistant to pump a few times, then hold pedal in.
5. Connect bleed tube.
6. Open bleed screw 1/4 of a turn for about a second, then do back up.
7. Assistant to let pedal back up gently.
8. Check master cylinder still has enough fluid
9. Do 6-7-8 a few times until air is expelled.
10. Move on to the drivers rear wheel, then the drivers front, then passenger front, doing 6-7-8-9 until all air out.
Is this right? Any help much appreciated
cheers
dave
1. Start Engine
cheers
dave
