Old 23-02-2011   #1
South Africa
Punto 2004 1.3JTD Not starting
Hi
A little while back My car satarted leaking diesel out of the front fuel pump, before I could get it to a garage it died spewing copius amounts of fuel.
I had it towed in and was told that I need the pump reconditioned - done - paid - car wont start?
Then I as told I need new glow plugs - done - paid - car won't start?
I took the car home by kick starting it, I just had the fuel filter replaced as well - no luck.
I can get the car to start if I use WYNNS ENGINE START - I have to spray
it into the turbo intake pipe and then she catches.
After reaching about 3000 revs she jerks then has limited power - cannot get over 3000 revs and engine light comes on.
Then she idles funny and dies randomly.
Please help my wallet is dying!
Vashthestampedo is offline Reply With Quote Quote
Old 23-02-2011   #2
Re: Punto 2004 1.3JTD Not starting
Tell us about the exhaust smoke (if any) ...
  1. White means fuel isnt being burnt either not atomised or poor compression
  2. Grey means the same but more likely poor atomisation
  3. Black means not enough air. Turbo hose burst or turbo failed but it usually starts normally
  4. Oily means piston blowby usually goes along with (2) or (3)
It might be the immobiliser but that should show the key light. I've read it prevents starting but wont prevent it running. I'm sure others can help with that.
DaveMcT is offline Reply With Quote Quote
Old 23-02-2011   #3
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
I'd have thought a fuel problem as it runs on the Wynnes stuff... checked the fuel filter & water trap?
Ex Suzuki SV1000S jockey, now a former 1.9 MJet Grande Punto Sporting pilot curently driving a Hyundai i30 1.6 Premium.
Ffoxy is offline Reply With Quote Quote
Old 23-02-2011   #4
Engine start helps diesels start when compression is low, so I'm coming from that angle.
It could be compression tested but its much more hassle on diesels. The ECU codes may be more helpful.
Old 28-02-2011   #5
Could be Injection pump timming
marting is offline Reply With Quote Quote
(T) 2004 2.0 jtd eleganza Starting issues sands030905 Ulysse 4 22-02-2011 13:46
(T) punto dynamic 2004 8v NOT STARTING mistakhan Punto (Mk2/2b) 6 15-09-2009 23:13
(G) 2.3jtd maxi 2004 problems prw Ducato 3 24-09-2008 11:27
(G) 2.3jtd maxi 2004 problems prw Ducato 1 15-09-2007 13:41
Punto 1.3jtd? faster4_tec Lets Talk FIAT 3 04-10-2006 10:37
